pat Posted August 25, 2013 Report Share Posted August 25, 2013 (edited) Hi all, Will ask if any of you have done an overhaul of the TYR rear suspension relay arm? Due to nipples mine lasted for ~29y..ok the play is NOK so could probably needed replacement 3y ago Do you know if the 2 bearings of same mesaurement, in the suspension relay arm , by any chance is industrial std bearings / seals? bearings pn 93315-31732-00 seals pn 93109-17048-00 Cheers, Edited August 25, 2013 by pat Quote Link to comment Share on other sites More sharing options...
bri66 Posted August 27, 2013 Report Share Posted August 27, 2013 Hi if you've got the bearing no.s try simplybearings,Brian Quote Link to comment Share on other sites More sharing options...
