mcman56 Posted August 27, 2013 Report Share Posted August 27, 2013 Are there any recommendations on removing the stop cam on a Rev3? This is the aluminium gizmo under the clutch cover and on the end of the shift drum. It is retained by what looks like a flat head screw but moderate force is not getting the screw to move. Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted August 27, 2013 Report Share Posted August 27, 2013 you probably will need to use an impact driver or a heat gun to loosen the locktight Quote Link to comment Share on other sites More sharing options...
mcman56 Posted August 27, 2013 Author Report Share Posted August 27, 2013 I had not thought about locktite. The hex is way too small for an impact driver but about 5 minutes with a heat gun did the trick. thanks! Quote Link to comment Share on other sites More sharing options...
