Gear Doesn
tirolean
Hi guys!
yesterday i recieved my new bearing, gaskets and so on.
but when i installed the two half bearings of the 5. and 6. gear, the gear doesn´t spin free
i´m a bit worried about that because if there is no gear at the bearings, they spin free and if i put the bearings in the gear, it does also spin free
maybe you have some tips for me
i´ll add a video i made
greets
Dani
http://www.youtube.com/watch?v=-thiZmu1BeA
Edited by tirolean
whats it like with oil on ,have the bearings gone on square without damage could the shaft be bent ,it seems something is incorrectly fitted or out of line or too much pressure ,are they tapered bearings could do with seeing the parts layed out in order of how they go together
Hi guys!
greets
Dani
Dani,
I would carefully inspect the inner and outer surfaces that contact the bearing needles (they are actually the inner and outer "races" of the bearing). They may be damaged. If so, those parts also need to be replaced.
Jon
