malcolm Posted August 27, 2013 Report Share Posted August 27, 2013 Hello all, I stripped the clutch on my 1993 Contact. When I took the plates out there were rubber/plastic (?) type discs in between. When I cleaned the oil from them they broke apart (all of them). Can anybody tell me what they are called and if I can get replacements? thanks Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted August 27, 2013 Report Share Posted August 27, 2013 are you referring to the cork fibre looking friction plates Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted August 28, 2013 Report Share Posted August 28, 2013 I had the same problem with my 94 JT25 when I had it. Those are the friction materials that should be bonded to the steel plates. It is time for a new set of friction plates. While you are in there, check the condition of the other plates and the fingers of the clutch basket. Look for any grooves worn in the fingers and the smooth movement of the plates in and out of the basket. Quote Link to comment Share on other sites More sharing options...
malcolm Posted August 28, 2013 Author Report Share Posted August 28, 2013 Hello guys, yes, its the cork looking discs but they don't seem to be bonded to anything. thanks Malcolm Quote Link to comment Share on other sites More sharing options...
tltel Posted August 28, 2013 Report Share Posted August 28, 2013 My sons 94 jt125 clutch did the same. bought the complete clutch from gas gas uk, think it was close to £100 and that was a couple of years ago. TLTEL Quote Link to comment Share on other sites More sharing options...
malcolm Posted August 28, 2013 Author Report Share Posted August 28, 2013 thanks TLTEL, nothings cheap in this game. Malcolm Quote Link to comment Share on other sites More sharing options...
dadof2 Posted August 28, 2013 Report Share Posted August 28, 2013 Try JK Hirst, I got a new set of clutch plates for a 95 gasser for about £50 Quote Link to comment Share on other sites More sharing options...
malcolm Posted August 29, 2013 Author Report Share Posted August 29, 2013 thanks dadof2 Quote Link to comment Share on other sites More sharing options...
