Gas Gas Contact 200 1993
malcolm
Hello all,
I stripped the clutch on my 1993 Contact. When I took the plates out there were rubber/plastic (?) type discs in between. When I cleaned the oil from them they broke apart (all of them). Can anybody tell me what they are called and if I can get replacements?
thanks
I had the same problem with my 94 JT25 when I had it. Those are the friction materials that should be bonded to the steel plates. It is time for a new set of friction plates. While you are in there, check the condition of the other plates and the fingers of the clutch basket. Look for any grooves worn in the fingers and the smooth movement of the plates in and out of the basket.
