hoodie2 Posted August 28, 2013 Report Share Posted August 28, 2013 Anyone out there with a TL Hi Boy who's got a good suspension set up, or other improvement suggestions? I've got 360mm betors that I'm planning to upgrade but I'm wondering if the Hi Boy geometry would suit longer shocks. Don't want to upset the steering though. Anyone any ideas on the ideal shock length and type for this bike? Any suggestions on front fork improvements also welcome. Bog standard at the moment. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted August 28, 2013 Report Share Posted August 28, 2013 Can;t advise on rear shocks but on standard TL it was worth removing the fork springs and fitting adjustable air pressure fork caps. Can't remember optimum PSI but I think it was between 5 and 15 Quote Link to comment Share on other sites More sharing options...
tltel Posted August 29, 2013 Report Share Posted August 29, 2013 Can;t advise on rear shocks but on standard TL it was worth removing the fork springs and fitting adjustable air pressure fork caps. Can't remember optimum PSI but I think it was between 5 and 15 Are saying that you run the bike without fork springs??? Not heard of that before!! TLTEL Quote Link to comment Share on other sites More sharing options...
hoodie2 Posted August 30, 2013 Author Report Share Posted August 30, 2013 I was wondering about that too. I'm assuming he means take the originals out and replace with something better. Anybody know of a set of forks with better springs and dampers that would fit the 31mm TL forks? Quote Link to comment Share on other sites More sharing options...
