Tl150 Hi Boy
hoodie2
Anyone out there with a TL Hi Boy who's got a good suspension set up, or other improvement suggestions? I've got 360mm betors that I'm planning to upgrade but I'm wondering if the Hi Boy geometry would suit longer shocks. Don't want to upset the steering though. Anyone any ideas on the ideal shock length and type for this bike?
Any suggestions on front fork improvements also welcome. Bog standard at the moment.
Thanks in advance.
Can;t advise on rear shocks but on standard TL it was worth removing the fork springs and fitting adjustable air pressure fork caps. Can't remember optimum PSI but I think it was between 5 and 15
Are saying that you run the bike without fork springs??? Not heard of that before!!
TLTEL
I was wondering about that too. I'm assuming he means take the originals out and replace with something better. Anybody know of a set of forks with better springs and dampers that would fit the 31mm TL forks?
