burnleytazz Posted August 28, 2013 Report Share Posted August 28, 2013 hi all all help is well appreciated i have slight play from the con rod about 1mm up and down what needs replacing crank bearings or the con rod itself or both? also noticed wear marks on the conrod itself? Quote Link to comment Share on other sites More sharing options...
copemech Posted August 28, 2013 Report Share Posted August 28, 2013 Conrod kit will have rod, bearing and pin. Then find you a shop to press the crank and true it. Quote Link to comment Share on other sites More sharing options...
burnleytazz Posted August 28, 2013 Author Report Share Posted August 28, 2013 Conrod kit will have rod, bearing and pin. Then find you a shop to press the crank and true it. So its gonna be expensive then roughly how much? Quote Link to comment Share on other sites More sharing options...
copemech Posted August 29, 2013 Report Share Posted August 29, 2013 (edited) Not sure about the parts cost, but I would guess you are spending 300 of your quid things! And add insult to injury, if the conrod is loose as you say, just do the mains and seals as well, Fact is, just send it off and let Gasser UK of someone do it if you are not set up. Saves a lot of grief. So up that to 500! Edited August 29, 2013 by copemech Quote Link to comment Share on other sites More sharing options...
gary tb Posted August 29, 2013 Report Share Posted August 29, 2013 http://www.grampianmotors.co.uk/ give grampian a ring for a crank rebuild Quote Link to comment Share on other sites More sharing options...
