gazzaecowarrior Posted August 30, 2013 Report Share Posted August 30, 2013 When I torque the rear axle to the recommend torque the wheel on my 09 250 evo just seems too tight and doesn't spin free. I read somewhere that sometimes the inner spacer between the bearings is often too big. Would this possibly be the case with mine ? When I slacken off the torque it spins fine. Any ideas ? Quote Link to comment Share on other sites More sharing options...
0007 Posted August 31, 2013 Report Share Posted August 31, 2013 It wouldn't be too big but if it was too short it could do what you refer to Does the spacer float freely between the bearings?, should be tight between the inner races Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted August 31, 2013 Author Report Share Posted August 31, 2013 It wouldn't be too big but if it was too short it could do what you refer to Does the spacer float freely between the bearings?, should be tight between the inner races Hi there. Yes it is tight between the bearings. Quote Link to comment Share on other sites More sharing options...
rokhopr Posted August 31, 2013 Report Share Posted August 31, 2013 Just throwing this in the mix.... Can't remember the year(s) but some of the rear wheel spacers are slightly different widths so it is important they are on the correct side of the wheel. The wheel will go on with them flipped but tightening up the axle locks things up. Quote Link to comment Share on other sites More sharing options...
mokwepa Posted September 1, 2013 Report Share Posted September 1, 2013 Just throwing this in the mix.... Can't remember the year(s) but some of the rear wheel spacers are slightly different widths so it is important they are on the correct side of the wheel. The wheel will go on with them flipped but tightening up the axle locks things up. What I think. Rev3 07 has different spacers. Guessing, if in incorrectly, will press disk up against caliper. Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted September 1, 2013 Author Report Share Posted September 1, 2013 Hi there Evo has equal spacers. At least mine does. Quote Link to comment Share on other sites More sharing options...
