jacks22 Posted August 31, 2013 Report Share Posted August 31, 2013 (edited) Bike : 08 290 Sherco Recent work to bike : Piston/barrel cleaned, new rings, new small end bearing squish set to 1.2mm - This removed the very small rattle at idle. New clutch basket / rubbers - This removed the clutch rattle New crank seals Dellorto PHBL 26 - 36 pilot 118 main 3.5 turns on fuel/air screw / stock everything else Ever time i start to bike up from cold there is a slight rattly noise from the top end after the bike has been rev'd, it happens just as it returns to idle. After a couple minutes it goes away as the bike heats up. Am just a bit worried as I would have thought this to be lean pinking/pinging but it shouldn't be lean as its on a 36 at 3.5. Not sure what octane the fuel is though ( fuelsave petrol / 62.5 ml of oil with 5L) Couldn't find any air leaks either... Or is it just the tolerances that make it rattle a bit, then as it heats up the tolerances become smaller? Edited August 31, 2013 by jacks22 1 Quote Link to comment Share on other sites More sharing options...
charlie chitlins Posted September 1, 2013 Report Share Posted September 1, 2013 Bike : 08 290 Sherco Recent work to bike : Piston/barrel cleaned, new rings, new small end bearing squish set to 1.2mm - This removed the very small rattle at idle. New clutch basket / rubbers - This removed the clutch rattle New crank seals Or is it just the tolerances that make it rattle a bit, then as it heats up the tolerances become smaller? This is likely. Quote Link to comment Share on other sites More sharing options...
copemech Posted September 1, 2013 Report Share Posted September 1, 2013 Yea, well, if only cold no big deal. Quote Link to comment Share on other sites More sharing options...
