malc Posted September 2, 2013 Report Share Posted September 2, 2013 I have a 200 sherco 2000 model with the square exhaust I am trying to sort the wiring as there is no CDI unit or diode etc. cant find any readings & schematic to understand what I need I have been told that a vespa CDI works I do have 1 which someone has given me its a mitsuba cmd01 but colours dont match so I am running blind. I have the stator plate leads, fan & temp sensor what else do I need? Thanks Malc Quote Link to comment Share on other sites More sharing options...
tony27 Posted September 2, 2013 Report Share Posted September 2, 2013 The cdi/coil unit you need is made by ducati electronica, I've seen a listing for the correct 1 somewhere, not sure where exactly but had a link to a scooter store's listing Quote Link to comment Share on other sites More sharing options...
malc Posted September 3, 2013 Author Report Share Posted September 3, 2013 http://www.ebay.co.uk/itm/290813266736?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Quote Link to comment Share on other sites More sharing options...
malc Posted September 3, 2013 Author Report Share Posted September 3, 2013 Also can someone please enlighten me to what colors go to where & what they are for please I have a yellow wire on its own, & a red, green & white wire together in the loom. Many thanks in advance Quote Link to comment Share on other sites More sharing options...
tony27 Posted September 3, 2013 Report Share Posted September 3, 2013 That looks to be the right unit. Yellow wire is the power for the fan Use this link to get an idea of which wires go where, it will show you how to run a normal killswitch instead of the standard switchgear. Looking at the photos the ignition used is the correct type for your bike but the leonelli ignition is wired exactly the same http://www.shercousa.com/pdfs/ryp_wiring_installation.pdf Hope this is of some help Quote Link to comment Share on other sites More sharing options...
malc Posted September 4, 2013 Author Report Share Posted September 4, 2013 I dont suppose you have some close up pics of how the unit fits to the frame as I cant make out how it secures Quote Link to comment Share on other sites More sharing options...
tony27 Posted September 5, 2013 Report Share Posted September 5, 2013 Don't have any photos of how it mounts but if you wait until the weekend I'll take the tank out & take some for you Quote Link to comment Share on other sites More sharing options...
asbo239 Posted September 6, 2013 Report Share Posted September 6, 2013 I used to have that bike, it used the ducati cdi and it was bolted onto a metal bracket that attaches inside the frame by the stocks, it was bolted with the bolt for the top of the tank. The red, white and green wire from the stator go to the cdi and yes the yellow wire is a 12v supply for the fan/lights etc but first it has to go through a voltage regulator/rectifier as the voltage from the stator increases with the revs. The rectifier sends anything over 12v to earth. Hope this helps Quote Link to comment Share on other sites More sharing options...
copemech Posted September 7, 2013 Report Share Posted September 7, 2013 I used to have that bike, it used the ducati cdi and it was bolted onto a metal bracket that attaches inside the frame by the stocks, it was bolted with the bolt for the top of the tank. The red, white and green wire from the stator go to the cdi and yes the yellow wire is a 12v supply for the fan/lights etc but first it has to go through a voltage regulator/rectifier as the voltage from the stator increases with the revs. The rectifier sends anything over 12v to earth. Hope this helps This is correct. It all works as in this early GasGas diagram, with the exception there are separate rectifier and regulator which need tied to the fan (yellow) circuit. For the fan, which is a DC motor, the rectifier(square box) is most important as otherwise you only have AC current. To limit the voltage at high revs, the regulator(rectangular) is used to shunt off excess voltage. Quote Link to comment Share on other sites More sharing options...
