September 6, 201313 yr Hello, New to the forum and from the united states. I have a 1993 gas gas 327 contact that has been difficult to find countershaft and rear sprockets for and the local dealer has no listing for it at all. My question is, is there any other motorcycles out there that have sprockets that would cross with my bike? The local bike shop seemed to think that the early 2000 gas gas endure bikes had the same rear sprocket as one of the Kawasaki dirtbikes, which got me wondering wha other sprockets, front or rear, may fit my 93 contact. Thanks for any help Shawn
September 6, 201313 yr Any sprockets from 1992/2002 pre Pro model should fit,here in Uk get them from e bay,http://www.ebay.co.u...=item5d42683b02 your rear sprocket should be a 6 hole fastening.http://www.ebay.co.uk/itm/New-GasGas-JT-JTX-JTR-TX-TXT-Trials-Chain-with-Talon-Front-Rear-Sprockets-/140999664075?pt=UK_Motorcycle_Parts&hash=item20d43c21cb Edited September 6, 201313 yr by bilks
September 6, 201313 yr Hi Shawn I have these sprockets in stock , rear £25 front £10 stevens trials 01732 824360 cheers Dave.
September 9, 201313 yr Author Thanks guy's, knowing up to 2002 fit may make it a bit easier to locate sprockets in the states.
September 9, 201313 yr My 95 Gas Gas has the same 6 bolt sprocket. I currently have a 42 tooth that was listed for a Sherco, it was the only one on ebay at the time that would fit my bike. So getting one shouldn't be a problem. Did'nt think of trying you. SHAVEY TLTEL
September 10, 201313 yr Did you try Rising Sun Imports? (The USA GASGAS parts importer) I cannot imagine Jim has no sprockets. I assume you are new to trials? Edited September 10, 201313 yr by lineaway
September 20, 201313 yr Author Thanks all for replying, been a bit busy and haven't had time to get back to working on the old gas gas. Not new to trials at all, but have been away from it for a while and got back into it when I found this old contact. I have priced sprockets from jim at $90 rear and $35 front. After a bit of shopping I can get both sprockets shipped from the uk for $60 and willing to wait for that kind of savings. Shavey, another problem just came up with loosing coolant with this bike and looks like it stems back to the coolant tank cap itself. I can only tighten it lightly before it pops loose like it is stripped. not sure if it is the tank threads or the cap threads, both look good and neither one is cracked or damaged that I can find. Also, I can blow freely through the cap overflow tube and im thinking that's not supposed to happen until enough pressure has built up to open the cap. Am I right on this? It completely drained the res in about an hour of riding yesterday. looks like it pushed it out the overflow tube. Thanks Shawn
