greg watts Posted September 7, 2013 Report Share Posted September 7, 2013 I think I know the answer to this, but just checking. - I've been giving my bike a pre-season going over and had the swing arm out to clean and grease the bearings. I thought I'd also do the lower shock bearing too, but the top hats don't seem to push out. I think they are probably a slight interference fit on the bearing and that really, this isn't just a 5 minute job like it is on the swing arm. Is that right? I've got a very small amount of play on the bottom shock mount, so in time I'll have to come back to this and replace the bearing I guess, but for now I just wanted to freshen things up down there. Am I right or am I missing something? Quote Link to comment Share on other sites More sharing options...
betabonkers Posted September 7, 2013 Report Share Posted September 7, 2013 Sounds like the bearing is gone, you don't put grease in there, a new one is about 30pound The top hats are very tight , not sure if they come with bearing or I used to buy them separate. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted September 7, 2013 Report Share Posted September 7, 2013 (edited) Yes, a tight push fit on a rev 3. You need a piece of round bar with a sharp burr on the end to get into the small groove between the two top hats, you can then tap the first side out I put grease in. The grease I use has high molybdenum disulphde content. Edited September 7, 2013 by dadof2 1 Quote Link to comment Share on other sites More sharing options...
