d250b Posted September 7, 2013 Report Share Posted September 7, 2013 When re-assembling an Amal carb, should you put anything on the new float chamber gasket? Oil or grease? Or should it go in dry? Also, would you put a wee bit of grease or Vaseline on the rubber 'o' rings on the jets? Cheers D Quote Link to comment Share on other sites More sharing options...
pro sport Posted September 7, 2013 Report Share Posted September 7, 2013 When I fitted a new float chamber gasket I didn't use anything as the petrol might dissolve it, anyway the gasket should seal on its own. The O ring on mixture screw might need a little rubber grease to aid fitting the O ring into the groove, and the same with the slow running screw. The main , needle , and pilot jets do not have O rings fitted, as far as i know. Quote Link to comment Share on other sites More sharing options...
crowley Posted September 8, 2013 Report Share Posted September 8, 2013 The gasket should go on dry, however, I have used a dab of grease if just refitting the float bowl to an awkwardly mounted carb - like the middle one on a Trident. As for O ring lube, why not use a smear of 2 smoke oil? Quote Link to comment Share on other sites More sharing options...
d250b Posted September 8, 2013 Author Report Share Posted September 8, 2013 Thanks for the replies, it's now back on the bike and once I've got the air filter sorted we'll see how she goes. Cheers D Quote Link to comment Share on other sites More sharing options...
