jfc Posted September 14, 2013 Report Share Posted September 14, 2013 Glad it helped (shocking sketch)! Quote Link to comment Share on other sites More sharing options...
sawtooth Posted September 14, 2013 Report Share Posted September 14, 2013 It was just what I needed :-) 1 Quote Link to comment Share on other sites More sharing options...
hoggyf Posted October 13, 2013 Author Report Share Posted October 13, 2013 Used it in anger a couple of weeks ago now and can't say there were any real negatives other than the magnet attaching itself to the exhaust, disc etc when you had it hanging off your wrist, switched off. It also cut the bike off when I launched it off the top of a step ! Lol Would recommend it as a useful upgrade. 1 Quote Link to comment Share on other sites More sharing options...
eviljim Posted May 10, 2014 Report Share Posted May 10, 2014 (edited) So which ones are worth buying? It's not the sort of thing you want to fail. Edited May 10, 2014 by eviljim Quote Link to comment Share on other sites More sharing options...
sawtooth Posted May 10, 2014 Report Share Posted May 10, 2014 I've had two cheap ebay ones and both rubber caps have failed, can't buy the rubber bit separately. So now have the Jitsie one. Quote Link to comment Share on other sites More sharing options...
taffe Posted May 10, 2014 Report Share Posted May 10, 2014 Jitsie, with spare cap and lanyard. Taff Quote Link to comment Share on other sites More sharing options...
monteberg Posted May 10, 2014 Report Share Posted May 10, 2014 hi all lanyard kill switches are a must on a snowmobile the problem of a physical tether is even worse because you move around so much more on the machine but when you have a big off its a must (to save not only the engine but the whole machine can become a runaway ) so some smart a has come up with a wireless kill switch little box on machine(snowmobile or bike) with an antenna and you wear or have with you the ´´KEY´´ when the 2 are seperated (you adjust the distance ) ignition is killed check out source innovation ltd in calgary (canada) its called teth air Quote Link to comment Share on other sites More sharing options...
