Lanyard Kill Switch - Good Or Bad?
hoggyf
  • 5 weeks later...
Used it in anger a couple of weeks ago now and can't say there were any real negatives other than the magnet attaching itself to the exhaust, disc etc when you had it hanging off your wrist, switched off. It also cut the bike off when I launched it off the top of a step ! Lol
Would recommend it as a useful upgrade.
  • 6 months later...
hi all
lanyard kill switches are a must on a snowmobile the problem of a physical tether is even worse because you move around so much more on the machine but when you have a big off its a must (to save not only the engine but the whole machine can become a runaway ) so some smart a has come up with a wireless kill switch little box on machine(snowmobile or bike) with an antenna and you wear or have with you the ´´KEY´´ when the 2 are seperated (you adjust the distance ) ignition is killed check out source innovation ltd in calgary (canada) its called teth air
