Removing Crank Shaft
fugazi
Thanks, yeah its a bike someone left in a shed in the rain for a couple of years, just trying to get it going again and yes I think they have dunked it a couple of times before putting it away, it is 12 years old.....
So basically the crank should just be in the bearing and should come out , its proper wedged in
Thanks for the replies
The Evo manual shows a pusher/ puller for removing the crank. I was able to make a plate that mounts to the cases. I bolted an existing puller to the plate so it was not that much work. FWIW, the Evo manual is almost an exact match to a 2008 Rev 3.
http://www.lewisportusa.com/manuals/beta/Trials%20service%20manuals/2010-2011_evo2t.pdf
