mccarro Posted September 13, 2013 Report Share Posted September 13, 2013 Replaced the rad on my 06 with an 02 , the thermostat is now mounted in the top hose as the older rads did not have them integrated thermostats. I've connected one connector on the thermostat to yellow wire from the small plastic box (dc convertor?) The other connector on thermostat goes to earth. Is this correct? It seem to work o.k. But the fan runs anti clockwise looking from the back - so is drawing air through the rad rather than blowing onto it. Again is this correct? I've not noticed which way it ran before swapping it over. Any advice welcome Quote Link to comment Share on other sites More sharing options...
lee99780 Posted September 13, 2013 Report Share Posted September 13, 2013 That's correct it should pull air through the rad not blow onto it Quote Link to comment Share on other sites More sharing options...
nelly1 Posted September 13, 2013 Report Share Posted September 13, 2013 That's correct it should pull air through the rad not blow onto it me too Quote Link to comment Share on other sites More sharing options...
