2007 Rev 3 250 Clutch Plate Tolorances
southwester
Hi, I cant find any info to see whether my clutch plates are worn below there minimum thickness and don't know what thickness a new set is? and also minimum clutch spring length, I have it all apart so thought I would do it while I'm here.
Its a shame Beta don't seem to have this sort of info printed anywhere or that I can find any way I saw a link on here the other day for Evo spec's but there isn't anything for the Rev 3 and knowt in the owners manual.
Can I use the specs for the Evo on the Rev 3?
If any body can help please do, If not I will contact Beta and post results.
Cheers.
Cheers.
You are making this way too hard. Put it back together and ride it. If the clutch is slipping order new plates. Twenty minute job if you are slow. Just throw it down on it`s side no fluid needed. Also the springs will be fine. There is all kinds of specs on the Gassers because of all the problems.
PS if you check part #`s between the rev3 and Evo, I would bet there are the same. There engine really has not changed too much through the years.
Edited by lineaway
