trumpy Posted September 15, 2013 Report Share Posted September 15, 2013 Hi can anyone tell me the best way to set up the carb on a 2009 evo 250 I just purchased this bike and arrived at the trial to find that fuel was pouring out the overflow. Stripped and cleaned it and it was ok after but the air screw setting got altered and the bike ran terrible all day. Is there a best way to get to a base setting ie turn the screw clockwise all the way and then back a turn? Do you have to pull the knob out before turning it? Is there a manual for this bike at all? Quote Link to comment Share on other sites More sharing options...
peterh Posted September 15, 2013 Report Share Posted September 15, 2013 Lots of information available http://www.betamotor.com/en/support/manuals http://www.beta-uk.com/index.php?option=com_content&view=article&id=48&Itemid=157 Quote Link to comment Share on other sites More sharing options...
trumpy Posted September 15, 2013 Author Report Share Posted September 15, 2013 Thanks for that it says all screwed in and 1 1/2 back so is that clockwise all the way and 1 1/2 back anti clockwise? Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted September 15, 2013 Report Share Posted September 15, 2013 screw it all the way in..back it out 1 and a half turns...after the bike warms up,,you can fine tune.. if you notice a little notch in your kicker lever???thats were i had mine stick out... one of the things i liked and miss about the 09 Beta evo. Quote Link to comment Share on other sites More sharing options...
peterh Posted September 15, 2013 Report Share Posted September 15, 2013 Yes - clockwise to close the airscrew and anticlockwise to open. At full in the bike will stutter, and stop if left too long - too rich. Back it out to 1.5 turns out as a starting position and then adjust 1/4 turn either in (clockwise - rich) or out (lean) to get the best idle. If you have to got out 2 or more then you have a different problem. Quote Link to comment Share on other sites More sharing options...
trumpy Posted September 15, 2013 Author Report Share Posted September 15, 2013 Thanks, Peter, it was running fine before I had to take the carb off so hopefully it should be OK I noticed towards the end of the trial that the bike was smoking more than normal if it was running to rich would it cause it to smoke? Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted September 15, 2013 Report Share Posted September 15, 2013 Yes, too rich will cause excessive smoking. Quote Link to comment Share on other sites More sharing options...
