imexian Posted September 15, 2013 Report Share Posted September 15, 2013 Hi been to man 17, hipwell trial today, brill effort from all involved ! Weather bit damp, to say the least!! After the 17 section, my fantic kicked back, knackered my dodgy ankle then kept slipping when I kicked it over. Had to leave it ticking over the rest of trial. What's up? Idle gear ? Anything else, easy fix? Anyone shed some light? Regards, Ian Quote Link to comment Share on other sites More sharing options...
grib Posted September 15, 2013 Report Share Posted September 15, 2013 I would guess it has knackered the teeth on the end of the kickstart shaft and/or the idler gear. Easy to check - take the clutch off and have a look. Idler gear easy to change, kickstart shaft means splitting the cases - not difficult but a bit more of a chore. Quote Link to comment Share on other sites More sharing options...
imexian Posted September 16, 2013 Author Report Share Posted September 16, 2013 Thanks for reply, hope its idle gear, as time is an issue with anything else!! i'll try to have a look later... Regards, Ian Quote Link to comment Share on other sites More sharing options...
grib Posted September 16, 2013 Report Share Posted September 16, 2013 Thinking about it - it won't be the shaft because the teeth aren't on the shaft; they are on a pawl on the end of the shaft - you could do either without splitting the cases. Quote Link to comment Share on other sites More sharing options...
