ham Posted June 18, 2005 Report Share Posted June 18, 2005 I have a 250 -04 sherco and I would like to know what size pilot jet should be fitted as standard ( the carburation is a bit 'blubbery'low down in the rev range, just above idle). It has a 35 in at the moment. P.S. I live in england and not up a mountain!--- Can anyone help ?Thanks. Quote Link to comment Share on other sites More sharing options...
outlaw dave Posted June 18, 2005 Report Share Posted June 18, 2005 Sherco - 2004 - Pilot 33 - check your fuel screw should be about 3 turns out Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted June 19, 2005 Report Share Posted June 19, 2005 Yep 33 is right,I use optimax or ultimate at 75 to 1 with fully synthetic. check the float level in case its miles out, check the banjo filter, treat it to a vx plug, it should be fine. jets available from MRS or Eurocarb Quote Link to comment Share on other sites More sharing options...
ham Posted June 27, 2005 Author Report Share Posted June 27, 2005 Thanks again fellas-Im off to spend some time and money on the Sherco.I'll keep you posted ! Quote Link to comment Share on other sites More sharing options...
