How To Install Crank Bearing/which Side Should The Seal Be
tirolean
hi guys!
I´m building togheter my TXT 2006 250 and i´m wondering, how i should put the crankshaft bearings in.
i´m not sure at which side the seal in the bearing should be => to the crankshaft or should it look to the ignition?
i hope you know the answer, because i haven´t found anything in the internet so far.
greets and thank in advantage
Dani
