350 Jumbo Newbee
rrich225
I just purchased a SWM 350 Jumbo, The bike is pretty complete and seems original. a couple ?s. The fuel line is way to close to the exhaust. What mod is done to prevent the fuel line from the heat. Thought I read about re-packing the midpipe. How is this done? Need a taillight and tank decals and side panel decals. I checked on SWM site in England but doesn't look like they have the parts. Any other tips and mods for this model.
Looks like I have bike number 201. When purchasing the bike I was told less than 20 were imported into USA. What is ballpark value for the bike?
For the fuel line:
get a spiral spring which is some mm bigger in diameter then the fuel hose and thread the spring over the hose.
Then slightly squeeze one or two windings of the spring so it holds on place.
For cleaning the mid section of the exhaust:
You have to cut it open then take out any remaining insulation, clean up the inner walls and hole tube, (sand blasting works very well), mount new exhaust insulation and reweld the mid pipe.
Edited by pschrauber
  • Like 2
