Brake Problem
casperrasper
Gasgas pro 2013 ...recently boiled back brake had flames .so I changed seals and piston on caliper bled up using swringe got pressure on pedal but I can't get the wheel to lock up when riding .im thinking have I scraped the disc ..any body got any ideas what the problem may be .....
Have you tried riding it round with your foot on the brake to get it hot again then chucking cold water on it? Worked for me, but sure someone will tell you it's bad for some reason.
How on earth did you manage to set fire to it in the first place though...?!
this usually works for me too
Cope's right again...or is it STILL right? ;)
Mild steel or cast iron, which most rotors are made of, can't be tempered, hardened, annealed, etc. because of its low carbon content....even if it does turn colors (oxides) like higher carbon tool steel.
It also rusts quite easily...just look at the rotors on your car if it sits in damp weather for a couple days.
This makes me unsure of what kind of steel trials bike disks are made of...they don't seem to rust.
If there is carbon or nickel (as with stainless), they could be affected by heat.
If anybody wants to send me an old one, I could heat it up and whack it around the anvil and give a report.
There are also charts that show the pattern of sparks different metals make when put to a grinding wheel.
Every one is different and old-time blacksmiths used to be able to put a piece of metal to a wheel and tell you what it was.
Good info Charlie
Also heating metal and letting it cool without quenching is what takes hardness out of steel
Quenching with water in particular increases hardness
Heating to 400 - 500f is all it takes to soften steel, not really all that hot
Most motorcycle disc rotors are stainless steel with a higher steel content because it's still magnetic.
Cast iron is to brittle, specialy for off road bikes. The only bikes I can remember that had cast iron discs where old Moto Guzzi's.
I drilled holes in the discs on my '98 315R and I can tell you that they where much harder than ordinary steel: I used a carbide drill for hardened steel which was blunt in no time.
Stainless doesn't have a particularly good friction coefficient.
When I had my repair shop (Harley related), a lot of folks wanted to switch to stainless rotors because form tends to trump function in that crowd.
It was pretty shocking how poorly the stainless rotors worked compared to stock.
Last I read (which was maybe 7 or 8 years ago), F1 was still using cast iron, but considering carbon fiber.
