chris 82 Posted September 29, 2013 Report Share Posted September 29, 2013 Could someone please give me any advice on starting my 280 txt 03 gas gas? I've heard people saying that they can be a pain to start.. It can be so bad that I leave it running the whole trial sometimes! Quote Link to comment Share on other sites More sharing options...
smalley250 Posted September 29, 2013 Report Share Posted September 29, 2013 Try raising the float level in the carb. Also dont touch the throttle and use the choke from cold. Quote Link to comment Share on other sites More sharing options...
chris 82 Posted September 29, 2013 Author Report Share Posted September 29, 2013 Thanks for the info. I should have mentioned I've been racing motorcycles for 20 years (2 strokes) and have never had any problems starting my bike but this gas gas is a right pain! My brother in law has one as well and his is exactly the same! Quote Link to comment Share on other sites More sharing options...
hamster Posted September 29, 2013 Report Share Posted September 29, 2013 the best way i could describe how i had to start my 06 300 gasser was by suprise lol 1 Quote Link to comment Share on other sites More sharing options...
squid_on_a_300 Posted September 30, 2013 Report Share Posted September 30, 2013 (edited) Always make sure your always in neutral choke only when cold and try this...lean the bike against something on the left hand grip to keep it upright..stand on the left peg and give it a full kick from the top of the kick starter engagement.....you cant be lazy ,you have to kick it like you mean it...once you figure out what type of kick it takes to start it, you can do it without leaning it against anything...same idea only now standing on the bike and balancing with your left foot on the peg give the bike the same type of kick you did when it was leaning against something..I had a hell of a time starting mine at first..leaning the bike against something to learn what type of kick it took to start it really helped me...like you I rode enduro bikes for 15 years prior to trials...you don’t kick them like a your other bikes...totally different technique...once you get your technique down you'll be good... Edited September 30, 2013 by squid_on_a_300 Quote Link to comment Share on other sites More sharing options...
chris 82 Posted September 30, 2013 Author Report Share Posted September 30, 2013 Thanks for the help, this is pretty much the way I have been starting it I just thought there might of been another trick to it :-) Thanks again.. Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted September 30, 2013 Report Share Posted September 30, 2013 what is your maintenance regime as these bikes start fairly easily normally? Quote Link to comment Share on other sites More sharing options...
toofasttim Posted September 30, 2013 Report Share Posted September 30, 2013 Trials bikes, because of their relatively high compression ratios, can be buggers to start. Dabster has a point, give the carb and ignition a going over and check to see if everything is in spec (timing, float height etc). To check whether it is the bike and not your technique get another Gasser rider (not your BIL) to try and start it. If he starts his own gasser without trouble and struggles starting yours it's probably the bike Quote Link to comment Share on other sites More sharing options...
sherpat Posted September 30, 2013 Report Share Posted September 30, 2013 I had trouble starting mine when I first got it. A friend recommended using the ball of my foot, rather than middle, and that does seem to add some leverage and speed to the kick. I'm not really sure if that made the difference, or if I just got the hang of it, but I don't have any trouble starting it now, hot or cold. Quote Link to comment Share on other sites More sharing options...
chris 82 Posted October 1, 2013 Author Report Share Posted October 1, 2013 Thanks for the help peeps.. I'm very good with the maintenance side of things being a mechanic and ex Grasstrack rider for 20 plus years. I think it is just getting the knack of it right :-) Thanks again.. Quote Link to comment Share on other sites More sharing options...
toofasttim Posted October 1, 2013 Report Share Posted October 1, 2013 On 10/1/2013 at 9:45 AM, chris 82 said: ex Grasstrack rider for 20 plus years. S'pose you'd be used to high compression motors then..... 1 Quote Link to comment Share on other sites More sharing options...
thumper darryl Posted October 21, 2013 Report Share Posted October 21, 2013 Not new to trials bikes, and have been riding various big bikes for years. I have owned 450 enduro bikes that I had no trouble starting. Previously had a 250 Sherco, and recently picked up a immaculate Raga 300 at a good price. I basically can not start this bike. Suggestions. Quote Link to comment Share on other sites More sharing options...
lee101 Posted October 21, 2013 Report Share Posted October 21, 2013 Hi darryl. I've had recent trouble starting my 07 txt pro 250. Turns out it was the stator. I borrowed one which I knew worked and it fired up first kick. Was a lot of head scratching moments as sometimes it would start, sometimes it wouldn't. I'm sending my stator off for a rewind and all should be sorted. I checked: Engine cut out. All earth cables and sanded the contacts. Checked flywheel. Compression. Replaced Bart gear and idler. ((was shredded) Quote Link to comment Share on other sites More sharing options...
thumper darryl Posted November 19, 2013 Report Share Posted November 19, 2013 Tried a 250 Gas Gas and no easier to start than my 300. Short stroke before kicker hits peg is main problem. Tried a couple of Beta's and Gas Gas is now for sale. Gas Gas is a beautiful bike that is fun to ride, but the starting issue takes all the fun out of riding. Even with the left side kicker, the Beta's are a breeze to kick over. Oh well. Quote Link to comment Share on other sites More sharing options...
paul_b1 Posted November 24, 2013 Report Share Posted November 24, 2013 My 03 280 Pro won't start in gear! Quote Link to comment Share on other sites More sharing options...
