paulmac Posted November 24, 2013 Report Share Posted November 24, 2013 Kick starting a gasser is technique but you could check that the plug is gapped at 0.6mm. Most new plugs are gapped at 1.2mm out of the box. Paul Mac Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted November 25, 2013 Report Share Posted November 25, 2013 My buddy has a 300 Raga and he had a hard time starting it. His 20 year old son can start it in one kick. The key we found is it has to spin fast to start. Bike must be in neutral, get the piston to top of the stroke, then a fast stab with the foot. Make sure the kicker is engaged at the top of the stroke before kicking. Gotta spin fast! Quote Link to comment Share on other sites More sharing options...
canada280i Posted November 25, 2013 Report Share Posted November 25, 2013 Ossa are the same, the quadrant start gear is what makes them difficult as you only have a small number of teeth that turn the crank for a short period so it needs a healthy stab to get things rotating Quote Link to comment Share on other sites More sharing options...
smalley250 Posted November 27, 2013 Report Share Posted November 27, 2013 I had to put mine on its side which did flood it. From that i adjusted float level and it was 100% better. The bike should be no worst than any other bike to start. Quote Link to comment Share on other sites More sharing options...
lee99780 Posted November 29, 2013 Report Share Posted November 29, 2013 They are renowned for hard starting. It's all in the technique. I had an 04 125-not a problem as you can imagine. Then I got my 06 300. Total different ball game! Had to have my mate hold it while I stood on pegs, making sure kickstart was at top and give it a good kick. I got a head spacer from trials enduro direct and it made a big difference. I can even start it mid section when I've fallen off now! Quote Link to comment Share on other sites More sharing options...
