How To Remove Fuel Tank On Gas Gas Contact 98
dave_pollard
Dave,
Removing the tank on the '90's Gassers is pretty easy. Right behind the head bearing there is should be a 1/4 turn fastener that holds the plastic cover on. Remove the fastener, disconnect the fuel line and lift the cover and tank out as an assembly.
You will probably be better served to post in the GasGas specific forum then this general one.
