sadlotus Posted October 5, 2013 Report Share Posted October 5, 2013 Hi all, Just aquired a Frontera 250cc/152, can't get a spark at all. Eventually after various tests I swapped over the stator from the Sherpa 92 and it sparked straight away. The frontera stator is gummy, dusty and covered in rust and sand. my question is: can I leave the Sherpa stator on? - they both look the same, both have lighting coils. Is there a performance difference between the two - between a revver and a slogger? Thanks Paul Quote Link to comment Share on other sites More sharing options...
boghopper350 Posted October 5, 2013 Report Share Posted October 5, 2013 Have you had it running? Quote Link to comment Share on other sites More sharing options...
sadlotus Posted October 5, 2013 Author Report Share Posted October 5, 2013 No. The seller said he'd had it running on brake cleaner... Not fully sure I believe that coz I've not had a spark yet. P Quote Link to comment Share on other sites More sharing options...
boghopper350 Posted October 5, 2013 Report Share Posted October 5, 2013 Try setting the timing and cleaning the carb etc. If you are getting a spark it should run. I'm not sure if the stator is the same on the different bikes, but there is no advance / retard, so you should be able to use it. At least if you can get it running you can clean the old stator, check the low tension coil, condenser and you should be away with that one. Someone will no doubt put you right on any difference between the two models. It's amazing what bull____ people come up with when they are trying to sell something, but I'm sure that you'll get it going. Good luck. Quote Link to comment Share on other sites More sharing options...
sadlotus Posted October 8, 2013 Author Report Share Posted October 8, 2013 Running. Used the Sherpa stator, set the points (just about) Set the timing (just about) Big backfire and kickback. Second kick started. The Frontera stator is a bit dilapidated. Broken coil. Anyone know what the red wire from stator is for? Seems to be the only difference. Quote Link to comment Share on other sites More sharing options...
matador107 Posted November 30, 2013 Report Share Posted November 30, 2013 The red wire that is found on some stator plates is a secondary lighting power supply feed. Example --split the rear tail/stop light to this wire and therefore more wattage is available to run the headlight. Quote Link to comment Share on other sites More sharing options...
