C15 Crank End Float
penno350
Can someone please help with advice on crank end float for a C15.
Based on Rupert Ratio and Google I am not clear whether it needs shimming to control the setting between crank and main bearing or is used to centre the con-rod in the barrel.
Either way it seems to need a ‘dry’ build to measure the clearance but assume this will not take account of any gasket material between the crankcase faces, although this will be minimal.
I have had the crank refurbished by Alpha bearings including a timing side bush to bearing conversion.
Any experience/advice gratefully received.
