Pod Foam Filters
andy m
What pod filters are people using. I need to use one on my Bantam, are the pit bike ones any use ?? Loads on ebay, not much else, thanks in advance
I mean air filters, k and n type but foam..
I use the cheap ones off ebay for around £6, look for the double foam ones, they have a 'sock' of coarse foam around a more mormally textured inner filter, I oil them both but the sock catches 90% of the crud and crucially most of the water, makes maintenance simple and better filtration than the pleated cotton ones you can see straight through
  • Like 2
Thanks, I ended up buying both, the pit bike type you mentioned and more expensive ramair type, the cheaper one is better, due to its double filter. Tried it out it breathes well , The ramair doesn't have the volume.
