0007 Posted October 24, 2013 Report Share Posted October 24, 2013 Air screw is a very fine adjustment and only matters when the throttle is closed Sounds more like your needle is lean, you could try dropping the clip one position Both my Rev and my Evo were lean on the pilot jet, mekes them fussy for set up of the air screw and lean hesitation off idle in cold weather Quote Link to comment Share on other sites More sharing options...
dan williams Posted October 26, 2013 Report Share Posted October 26, 2013 On my 2013 I went up one size on the pilot. Even running VP C12 this improved the response. Fuel is not always what they tell you at the pump which is why I buy cans of race gas. Quote Link to comment Share on other sites More sharing options...
0007 Posted October 26, 2013 Report Share Posted October 26, 2013 Fuel is as big a scam as anything Octane ratings are simply the ability to resist detonation, fuels are designed specifically for fuel injected multi cylinder four cycle engines In canada we have winter and summer fuel as well which changes things based on seasons Quote Link to comment Share on other sites More sharing options...
skyline1 Posted November 1, 2013 Author Report Share Posted November 1, 2013 Just dropped the clip on my carb needle it was already one down from the middle so is now on the bottom, then adjusted the air fuel screw. I will be out on the bike tomorrow or Sunday but it seams fine at the moment. Quote Link to comment Share on other sites More sharing options...
copemech Posted November 3, 2013 Report Share Posted November 3, 2013 A throttle chop ping is not necessarily unusual it seems. If you think about it, when you chop throttle you cut fuel as well so things may go lean. Only thing feeding fuel in is primary circuit, so it makes sense that an increase in pilot jet size may help. What jets are in it? On the Kiehin, seems 45-48 range is not uncommon, not sure about your area fuel. Quote Link to comment Share on other sites More sharing options...
skyline1 Posted November 3, 2013 Author Report Share Posted November 3, 2013 Many thanks for your help everybody. Dropping the clip seems to have done the job, no pinking today. I just have to get the air-fuel mix spot on & she will be right. I am on the bottom of the needle so any more & jet size would have needed changing. Quote Link to comment Share on other sites More sharing options...
0007 Posted November 4, 2013 Report Share Posted November 4, 2013 (edited) Well the top end of the pilot circuit and the bottom side of the needle circuit sort of coincide It's kind of unusual to need to move the clip to that position when other riders don't I suspect the is is something else going on and adjusting the needle is masking it Has the float height been lowered substantially at any point?, fuel level will effect the same circuit Edited November 4, 2013 by 0007 Quote Link to comment Share on other sites More sharing options...
Rhyshott92 Posted June 22, 2021 Report Share Posted June 22, 2021 Did you cure this problem as I have the same when bike is under load half throttle it makes a ticking clicking noise Quote Link to comment Share on other sites More sharing options...
Rhyshott92 Posted June 22, 2021 Report Share Posted June 22, 2021 On 11/1/2013 at 7:56 PM, skyline1 said: Just dropped the clip on my carb needle it was already one down from the middle so is now on the bottom, then adjusted the air fuel screw. I will be out on the bike tomorrow or Sunday but it seams fine at the moment. Expand Did you cure this problem as i have the same as you describe Quote Link to comment Share on other sites More sharing options...
