davidorothy Posted October 11, 2013 Report Share Posted October 11, 2013 Just recently fitted this kill switch instead of the standard Beta kill switch. For some reason it has suddenly stopped working. Tried all the standard connections without any success. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
laser1 Posted October 11, 2013 Report Share Posted October 11, 2013 Check your ground connection. Quote Link to comment Share on other sites More sharing options...
jj65 Posted October 11, 2013 Report Share Posted October 11, 2013 (edited) Check the spring inside, has been known to stick. Edited October 11, 2013 by jj65 Quote Link to comment Share on other sites More sharing options...
davidorothy Posted October 12, 2013 Author Report Share Posted October 12, 2013 The bike is an Evo 250. How do i check the ground connection. Quote Link to comment Share on other sites More sharing options...
hoggyf Posted October 13, 2013 Report Share Posted October 13, 2013 Might be bing a bit simplistic here but. ... The kill switch is basically a switch in line which earths out to the frame You need to trace back your wires, one is effectively a supply to the switch (in) and the other (out) will connect to the frame. If you've got a multi meter, set it to buzz and connect one probe to the frame and the other to the cable above where it connects to the frame, you should get a buzz, if so it's good, now check it at the kill switch itself as we'll, now disconnect the supply (in) part and connect the probe to there and press the kill switch and if working it should, buzz. Hope that helps, it's hard to explain in words. Quote Link to comment Share on other sites More sharing options...
0007 Posted October 16, 2013 Report Share Posted October 16, 2013 Is it possible you just wired the ground to ground rather than the ignition to ground? Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted March 31, 2017 Report Share Posted March 31, 2017 Anyone know how to take the switch apart to see if there's anything sticking in there Quote Link to comment Share on other sites More sharing options...
