2006 Gas Gas
cota kid
Hardly any different to the 05. :D perhaps theres some mechanical differences ie New thermostat :D ...
Just looked at it again and its got an ohlins shock!!!
Edited by Jools
Any dealers on here know when you are recieving them? :D
Have to hard wire that re-map thing on the Handlebars.
Yeah, you can read on the description that the ohlins save another kilo! s**t!
Talked to Charlie Jagger about them a couple of weeks ago. The build should start next month probably with the 250/280 them move on to the 125 and the 200/300. Hence we should start seeing them sometime in late July /August. Personally I'm not sure if the 200 will be continued.
Chris is hoping the 05 125 racing mods are carried to the 06 model.
Translation of page below. (Kitchen maid?????)
The Gas range appears 2006 Gas Kitchen maid in the image to extend it Gas Gas Motos finishes presenting/displaying the new range of motorcycles and quads for 2006 in which they emphasize a great number of new features, as much in which it affects the evolution of some products stars of the mark, like a the introduction of new motorcycles, quads, mechanical motors and elements that come to add themselves to the extensive catalogue of the Spanish company/signature, that now arrives until the 33 different models, between trial versions, enduro, motos for children, cross, supermotard, hybrids and the ample fan of quads that already reaches a supply that goes up to around the six different models. The new range Gas Gas 2006 will leave the line of production of gradual form throughout second half of the year, the first units as of the next month of July. Gas Gas, through his renewed Technical Office, in narrow collaboration with the people in charge of project of Trial, Enduro and Quads and of the Department of Engineering of Production, has designed a range that emphasizes mainly by the improvement of concepts that from always have been the great strongpoints of products of the mark: the technical yield and the dynamic quality of conduction. New the Gas Gas 2006 sees increased their attributes remarkably, in a constant fight to be able to reduce the weight and to increase their quality as far as mechanical and finished elements. Kitchen maid in the image to extend it Trial: Perfecting to the motorcycle leader All the Gas Gas TXT Pro of 2006 sees reduced their weight. Gas Gas thinks that the reduction of weight in the motociclismo of outside highway still is very far from arriving at its limit, reason why year after year presents/displays its mounts with grams of less than they turn unquestionable leaders as far as agility and behavior. The TXT are the unique ones in the world that equip of series the front suspension with aluminum bars instead of steel, which reduces in 1 kg the weight of the set and it turns them lightest of his category. The suspensions are adjustable in all their elements, being the back shock absorber of the mark
Edited by Telecat
This suggests alloy fork tubes (stantions) over steel. Would save the 1 Kg they quote. Interesting !
