Txt Primary Drive Ratio
farmerj
Take the primary drive cover off and count the teeth on the clutch and crank pinion
At a guess it will be be around the 5 or 6 to 1 mark with the actual teeth numbers being prime
Edited by dadof2
what would you possibly be needing this information for? I have ridden all these years, never wanted to know the "drive ratio", ever, lol.
Great question! I have a Husaberg FX 450 with a close ratio transmission, and 1st gear is just too high for some of the riding I do. So I've been comparing final drive ratios with my other bikes, after running them all through the same trail/course. I thought I'd try to see what it would take to get the FX 1st to compare to 2nd or 3rd in the TXT...so I'm having fun with a spreadsheet and learning a lot about gearing!
