98 Techno Carb Settings
starr870
Hi if u have a good idle,try and slow it down with the slide screw,to a acceptable level without stalling then adjust your air screw to see if the engine speeds up or down,the rough starting point for the air screw is about 1 1/2 turns from fully in,make sure your engine is fully warmed up.also check your plug to check the mixture.
  • 1 month later...
