Shortening Ceriani/betor Forks
drake
hi drake its a fairly easy to shorten them but do it from the bottom so you dont have to rethread the tops cut the 2inches off with disk cutter because chrome is very hard then counter bore for the alloy tube then circlip groove follow what was in the the bit u cut off i never shortened the dampers just the springs worked ok for me best of luck stan
