j@mes Posted June 28, 2005 Report Share Posted June 28, 2005 pretty certain my dads 03 250 pro has one piece arbox rubber Quote Link to comment Share on other sites More sharing options...
subira Posted June 28, 2005 Report Share Posted June 28, 2005 Talking of carb boot.... is mine just a one off. My 2003 has a one piece tube from airfilter to carb, no doughnut rubber thing. Strange they only list a BT280328017 part for all cc's in 03 and its still the same in 05 again across the range. Check the part number stamped on it. Its a pain to change, as around the 'TUBE, AIR CLEANER CONNECT' is the one place Senior Gasser managed to use plenty of sealant. I can't figure out why the sealant is put on how it is Lots of sweat and swearing required to seperate it from the airbox bottom half - I split the box to change it, as I was fitting a new bottom half. Quote Link to comment Share on other sites More sharing options...
ikb Posted June 28, 2005 Report Share Posted June 28, 2005 I got rid of the rubber donut by machining a ally spacer clamped to the carb, as its a bit longer the air box is really easy to refit. Ian Quote Link to comment Share on other sites More sharing options...
