Silencer
baldilocks
Before I get the hacksaw out does anyone have a diagram showing the location of the baffle plates on a 320 ? Have pushed a long screw driver through from where the silencer joins the middle box but cant find anything. The box has been previously welded and im wondering if one or both of the plates has been removed. The baffle tube is still present at the entry point.
There is somthing in there rattling as you can hear it when the engine is running but shaking the box it doesn't rattle ?
Glen, don't think a TXR system will fit, without altering the pipe into 2 pieces, and cutting dowm the head fins on the right hand side. You gouing to seaton delaval on sunday ? Have a look at cylinder head then. Ross
  • 4 weeks later...
Mine was similar to that inside Ross but the exit tube was much shorter and there was another chamber before the original two small exit pipes. The noise was from the large plate with the square hole in rattling as it was only spot welded. Bike goes much better now but this is more to do with lowering the needle from standard and replacing jets with new ones.
:popcorn:
Very cool, again a Helmholtz resonater muffler, which was very commen back in the early eighties. A system of different tubes and recesses combined with a sequence of different volume. Each of them is responible to reduce noise of a cretain wavelength. Technical the Helmholtz resonators works as a resonance absorber, this princip is still used in building acoustics.
Disadvantage of this design is that it exerts a certain constant back pressure as the exhaust gases are led through a maze, which costs power. But the engine runs very evenly so.
  • Like 2
