300 Pro - Long Pipe Or Low Compression Head
wright4d
Low compression head reduces cylinder pressure and power at all RPM.
In a 2 stroke pressure waves travel along the exhaust pipe and then bounce back from changes in exhaust diameter. Changing the length of the pipe changes the distance the waves have to travel and therefore the time they take. This changes the RPM at which the effect of the waves occur. Increasing the length of the pipe gives more time for the wave energy to dissipate. The overall result of pipe lengthening (without other changes) is often a loss of peak power and a flattening of the torque curve but it often softens the feel of the power at low RPM and makes the bike less likely to stall.
