mac Posted November 9, 2013 Report Share Posted November 9, 2013 I am in the process of fitting a 301 engine into a 240 frame and just noticed this on ebay whilst looking for a airbox? http://www.ebay.co.uk/itm/Fantic-125-200-240-Professional-Trials-Rear-Engine-mount-/161144429482?pt=UK_Motorcycle_Parts&hash=item2584f4dbaa Is this the correct fitting for a 240 rather than the 2 handle bar clamp like fitting from the 301? Quote Link to comment Share on other sites More sharing options...
blocky Posted November 9, 2013 Report Share Posted November 9, 2013 Yes Quote Link to comment Share on other sites More sharing options...
wobbler Posted November 11, 2013 Report Share Posted November 11, 2013 Any chance of some pictures as you go along - especially the right hand lower frame tube mod (& cutting dimensions etc) as I have a 240 frame in build at the minute that I would like to get modded so I can drop a 301/303 engine straight in at a later date. Cheers The Wobbler Quote Link to comment Share on other sites More sharing options...
mac Posted December 22, 2013 Author Report Share Posted December 22, 2013 Sorry for the delay - Latest on the fantic 301/240 - As you mentioned above the lower frame has to be cut away to accept the bigger fly wheel of the 01 serious engines . I don't have any measurements but basically ground away ( with a angle grinder) just under half of the lower tube over a length of about 10 or 12cm and then welded in a plate to reinforce it. I kept trying the engine in to see how much need taking away till the engine fitted in nicely plus a bit of clearance room . Next problem is the exhaust from the 301 wont fit in so need to get some advice on that but looks as if i need to cut it and add a bit in? I still have the 240 yokes on but need to get either the 200 yokes or i might try the 301 yokes i have but the roller bearing are a different inner diameter so need to get down to may local bearing shop ones the holidays are over. Still need a few bits but getting there i think ! Big thanks to Lee Harris and Richard Allen for some top advice .Will get some pictures out soon. Quote Link to comment Share on other sites More sharing options...
