jeffm Posted November 9, 2013 Report Share Posted November 9, 2013 The fill point on my Txt 280 is so small I make a big mess with the ATF Anyone know where I can get a funnel small enough? What methods or tricks do you use to make it easier to fill? Thanks Quote Link to comment Share on other sites More sharing options...
tltel Posted November 9, 2013 Report Share Posted November 9, 2013 Buy a small 1 litre bottle of ATF and it will most likely have a tube in the lid that fits nicely in the filler hole. I have a few small bottles and fill them from a 5 lire can, same goes for fork oil keep them clean and reuse over and over. Simples! TLTEL 1 Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted November 9, 2013 Report Share Posted November 9, 2013 Get hold of some medical syringes, will do the job nicely for engine/fork oil and mixing fuel. The tip will fit in the narrowest of filler holes and you can measure precisely how much oil you're putting in (gauge on side of syringe and no residue left after you've finished). 1 Quote Link to comment Share on other sites More sharing options...
laser1 Posted November 9, 2013 Report Share Posted November 9, 2013 Jitsie makes a screw in pipe that makes changes really easy. You dont need one, but it helps. 1 Quote Link to comment Share on other sites More sharing options...
peterh Posted November 10, 2013 Report Share Posted November 10, 2013 from the kitchen draw - just clean it well before someone finds out! Cheap as plastic from anywhere though! Quote Link to comment Share on other sites More sharing options...
lee101 Posted November 12, 2013 Report Share Posted November 12, 2013 I use a funnel with a piece of brake hose attatched to the bottom, cable tie it to your frame and pour your ATF in. Simples. 2 Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 12, 2013 Report Share Posted November 12, 2013 Get the cap off an old hypoid bottle. It will fit most, except the new wide mouth. http://www.spraysmar...CFfFj7AodgDkAzg Quote Link to comment Share on other sites More sharing options...
jeffm Posted November 12, 2013 Author Report Share Posted November 12, 2013 Thanks. Some good ideas. I did try the kitchen one time for something to clean my filter in. Lets just say I won't make that mistake again. LOL 2 Quote Link to comment Share on other sites More sharing options...
mr neutron Posted November 13, 2013 Report Share Posted November 13, 2013 Jeff, I use a small funnel that I think was made for Coleman stoves & lanterns, to put fuel (white gas) into their tanks, with the piece of hose mentioned above. The funnels are found at sporting goods stores in the backpacking/camping department, and hose at any hardware store..... There's some great suggestions here, fellas! Jimmie Quote Link to comment Share on other sites More sharing options...
peterh Posted November 13, 2013 Report Share Posted November 13, 2013 Thanks. Some good ideas. I did try the kitchen one time for something to clean my filter in. Lets just say I won't make that mistake again. LOL Yes, Jimmie - when I got back into to riding trials, my better half was quite glad that disc brakes were now on bikes. No more drying Montesa brakes pads in the oven. Well at least that way they worked for the first few minutes until they found water again. But now the No-toil airfilter literature says I can put my airfilter in with the washing. I might hold back on that one! Do not want to upset the cheque book holder . 1 Quote Link to comment Share on other sites More sharing options...
dandabs Posted June 12, 2014 Report Share Posted June 12, 2014 I took a Starbucks straw and put it through the smallest filter I had and taped around where they meet to keep the oil in there from leaking. Amazingly it worked. That hole is SERIOUSLY small!!! Quote Link to comment Share on other sites More sharing options...
dandabs Posted June 12, 2014 Report Share Posted June 12, 2014 You could also buy a squirt drink bottle (the type hockey players use) it has a ridiculously small pointy tube. Quote Link to comment Share on other sites More sharing options...
