spike2450 Posted June 26, 2005 Report Share Posted June 26, 2005 Hi Is there such a thing as a owners or workshop manual for the gas gas. For instance there are adjusters on top of the forks, (ideal settings) etc. And others for the novice, tyre pressures, oil mix ratio and it seems that Castrol tts is popular? Any help would be great. Found a good site today http://www.trialstrainingcenter.com/html/how_to_ride.html cheers Quote Link to comment Share on other sites More sharing options...
stuessenhigh Posted June 27, 2005 Report Share Posted June 27, 2005 Over here most people run about 6psi in the front and about 4psi in the rear. Hope that helps ...thanks for the link to that site..will check it out now Quote Link to comment Share on other sites More sharing options...
spike2450 Posted June 27, 2005 Author Report Share Posted June 27, 2005 Hi Thanks for all the info, it's a txt model with adjusters as you described. However both adjusters have been turned fully out, can you let me know how many settings there are and what would be a good starting point ? (I'm 12 stone ex MXer but only novice at trials). Sorry for so many questions but my front brake was crap, so i've bled them and found two slightly seized pistons (wheel side). The brakes are now slightly better, but i would like to strip the caliper, is it ok to take the two halves of the caliper apart? Thanks for everyones help dave Quote Link to comment Share on other sites More sharing options...
jtt Posted June 28, 2005 Report Share Posted June 28, 2005 Hey Spike, I think r2 pretty much covered the fork thing. The clickers are not as effective as the ones your probably used to on MX bikes, very subtle adjustments I've found. If I remember correctly I think they use 300cc of oil per leg. One leg is rebound, one is compression. You can vary fork oil weights to get the results you want if your keen. Basically I think r2's advise about balancing the front to the rear is the single biggest thing, particularly for beginners. As for your brakes, once you get everything back together give them a good "seasoning". By that I mean get your garden hose out and ride around the yard for a few minutes with the brake on, dragging. Get the rotor good and hot (not to the point of discolouration, but pretty hot) and while it's still hot hit it with the cold water. Do this a couple of times and I think you'll be very impressed with the improvement. I'm not quite sure why it works, but know it does. Had a Sherco back a few years ago with horrible brakes...seasoned them regularly and they were fine. Not usually a problem with the newer 4 piston calipers, but seems to be more pronounced on the two piston models. Quote Link to comment Share on other sites More sharing options...
kenny123 Posted June 29, 2005 Report Share Posted June 29, 2005 (edited) i have split my caliper before but one thing i didint see is that there is a really small seal. which i lost. so i had to buy a full new piston kit. if i remember rightly Edited June 29, 2005 by kenny123 Quote Link to comment Share on other sites More sharing options...
