biggegg Posted November 19, 2013 Report Share Posted November 19, 2013 hi,i'm going to be fitting a new clutch, and after checking which oil to use it says on a couple of gg websites 10w40 and the other says 5w30 and i'm sure one said not a synthetic oil??? on our gg125(1993) we use a 75w(i think) also unsure what fuel mix ratio i should use,one the gg 125 and sherco 290 i use 80-1 and i was going to use the same mix for the gg 80 until i found on a website that it should be 50-1 and another said 1.5%????? information overload!!!! Quote Link to comment Share on other sites More sharing options...
lineaway Posted November 20, 2013 Report Share Posted November 20, 2013 (edited) The 80 will actually work with all those oils, and 80;1 will be fine. Ps, just do not run the ty80 at that! Edited November 20, 2013 by lineaway Quote Link to comment Share on other sites More sharing options...
biggegg Posted November 20, 2013 Author Report Share Posted November 20, 2013 so 10-40 or 5-30 either will work with the new clutch? as for the ty it is running on about 30-40:1(just been re-bored and had less than one tank of fuel through it) Quote Link to comment Share on other sites More sharing options...
