dazzagreener Posted November 22, 2013 Report Share Posted November 22, 2013 As the title says. Has anyone got an ideal clutch lever set up for someone like me with small hands. I tried moving the lever stop so I don't have to reach so far but when I pull the lever in now the clutch doesn't engage and drags. Any help would be good Cheers Quote Link to comment Share on other sites More sharing options...
nelly1 Posted November 22, 2013 Report Share Posted November 22, 2013 now you need to wind out the other adjuster the one with the 10mm lock nut 1 Quote Link to comment Share on other sites More sharing options...
jer Posted November 23, 2013 Report Share Posted November 23, 2013 I have the same problem. For a couple of years i used a master cylinder with a bigger bore, 10.5mm compared to 9.5mm diameter. It was better in that it didn't take so much lever movement to clear the clutch, it didn't drag. It was worse in that it was a bit stiffer to pull and much more 'on or off', so not so good for creeping round tight corners. What I'm doing now is using the standard Beta master cylinder but using VERY careful adjustment to get it just perfect. Make sure there is no wear in the pivot, the hole in the lever can go oval. Make sure the lever isn't bent out at all. Quote Link to comment Share on other sites More sharing options...
sectionone Posted November 24, 2013 Report Share Posted November 24, 2013 I use a nylon strap from a dog leash attached at the ball and hose clamped past the dogleg with enough room to fit your index finger between the strap and lever. I also soak the strap with black enamel paint to make it stiff with some flex. This setup gives me more leverage on both clutch and brake and reduces fatigue. I can still use two or four fingers on the lever for shifting or full clutch disengage. Quote Link to comment Share on other sites More sharing options...
dazzagreener Posted November 24, 2013 Author Report Share Posted November 24, 2013 Can't really see what you mean mate. Have you any pics Quote Link to comment Share on other sites More sharing options...
sectionone Posted December 3, 2013 Report Share Posted December 3, 2013 Quote Link to comment Share on other sites More sharing options...
charlie chitlins Posted December 5, 2013 Report Share Posted December 5, 2013 You can also use a very short lever. It can be pulled all the way to the grip without hitting your fingers, so you can adjust it further in. It's a 1-finger deal, though. If your finger gets tired as the day wears on, it's not easy to fit another finger on there to help out. Quote Link to comment Share on other sites More sharing options...
