anotherfive Posted November 24, 2013 Report Share Posted November 24, 2013 Hi Has anyone tried removing peeling decals, cleaned them, then reapplied. If so what glue did you use and was it worth it? Cheers Quote Link to comment Share on other sites More sharing options...
wmc37 Posted November 24, 2013 Report Share Posted November 24, 2013 Hi, Don't bother trying to peel them off, stick the peeling bit back down with superglue then run a bead of superglue round the edge of the decal. this usually works OK but superglue is water soluble so you have to keep running another bead round the decal every so often. Hope this helps. Quote Link to comment Share on other sites More sharing options...
