Gas Gas Txt Pro 280 2002
chris west
Hi can anyone help . I'm a new rider and have bagged myself a gas gas txt pro 280 2002 model. I've done loads to this bike since I got it a month ago. Discs , pads , full service , bearings , chain sprockets and much more. When I'm pottering about on it though it seems a little jerky at low revs in low gears . .ive stripped the carb down and all jets are spot on and clean ans chain seems tight enough. It's almost like this beast just wants to go all the time. Is this normal. Any help much appreciated . Chris
Dam just installed a 11 tooth .. Back to ebay then . Thanks guys
The 10T will help. They did seem a little high geared and I run an 11/44 combo on mine. What jetting do you have in the carb? There are a lot of other things that may cause the symptoms, like old fuel, tattered reeds or worn rings etc. I also have a 2002 280 and it runs silky smooth.
Jon
