chris west Posted December 5, 2013 Report Share Posted December 5, 2013 Can anyone help I am after the four o rings that are in exhaust system . There are two from down pipe to exp chamber and two from chamber to the rear can . I'm after a uk stockist please gents . Any help appreciated . Sorry 2004 txt 280 pro . Thanks Quote Link to comment Share on other sites More sharing options...
bilks Posted December 5, 2013 Report Share Posted December 5, 2013 (edited) Try here http://www.haventria...th=1679_646_692 but ring or e mail to make sure in stock,because he does not tell you if they are or not,when you order online. Edited December 5, 2013 by bilks Quote Link to comment Share on other sites More sharing options...
chris west Posted December 5, 2013 Author Report Share Posted December 5, 2013 Thanks mate Quote Link to comment Share on other sites More sharing options...
chris west Posted December 5, 2013 Author Report Share Posted December 5, 2013 Ism a bit desparate for them .. Out on Saturday .. Any ides for a temp solution . Quote Link to comment Share on other sites More sharing options...
jse Posted December 5, 2013 Report Share Posted December 5, 2013 Ism a bit desparate for them .. Out on Saturday .. Any ides for a temp solution . Hi-temp Silicone, be sure to let set overnight. When you put whole exhaust system together, don't tighten fasteners. When whole system installed, tighten from cylinder headpipe back to rear muffler. Jon Quote Link to comment Share on other sites More sharing options...
chris west Posted December 5, 2013 Author Report Share Posted December 5, 2013 Thanks Jon .. Will this suffice long term or are the o rings essential .. I'm soaking mid box.and head pipe in caustic tomorrow .. They are steel so should be fine ??. I hope ... The expansion chamber is almost blocked solid .. Once this exhaust is sorted .. The bikes ready to trial . It's been a long road but sense of acheivement out ways all .. Thanks Quote Link to comment Share on other sites More sharing options...
jse Posted December 6, 2013 Report Share Posted December 6, 2013 Thanks Jon .. Will this suffice long term or are the o rings essential .. I'm soaking mid box.and head pipe in caustic tomorrow .. They are steel so should be fine ??. I hope ... The expansion chamber is almost blocked solid .. Once this exhaust is sorted .. The bikes ready to trial . It's been a long road but sense of acheivement out ways all .. Thanks I use a combination of the o-rings and carefully applied hi-temp Silicone, but I like a tight exhaust system. I'd do the hi-temp and see how long it lasts. The o-rings are hi-temp Silicone..... Jon 1 Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted December 6, 2013 Report Share Posted December 6, 2013 I used high temp silicone seal for over a year on mine. Worked fine. Quote Link to comment Share on other sites More sharing options...
richt Posted December 6, 2013 Report Share Posted December 6, 2013 I don't know where you are located but GGuk have everything. as well as the O-rings Quote Link to comment Share on other sites More sharing options...
chris west Posted December 6, 2013 Author Report Share Posted December 6, 2013 Thanks ordered from gguk... Thanks pal Quote Link to comment Share on other sites More sharing options...
