chris west Posted December 6, 2013 Report Share Posted December 6, 2013 Hi all . Had my exhaust mid and front in caustic for about three hours and not much going on at all . I fill with cold water and yeah the water has warmed but not the reaction I was expecting .. How long till all that oily grime starts shifting .... Thanks in advance . Chris . Quote Link to comment Share on other sites More sharing options...
0007 Posted December 6, 2013 Report Share Posted December 6, 2013 The answer to all of life's questions starts with Caustic soda http://www.causticsodapodcast.com This is truly great stuff Quote Link to comment Share on other sites More sharing options...
chris west Posted December 6, 2013 Author Report Share Posted December 6, 2013 Hahaha Quote Link to comment Share on other sites More sharing options...
rij Posted December 6, 2013 Report Share Posted December 6, 2013 Be very careful aluminium can disappear using caustic soda (this was on a beta rev3 mid section) it went in the bin! and a friend had to buy a new one Steel is fine with it Rich Quote Link to comment Share on other sites More sharing options...
chris west Posted December 6, 2013 Author Report Share Posted December 6, 2013 Mid section is magnetic on my gasser so it's steel .. I hope .?? Quote Link to comment Share on other sites More sharing options...
bilks Posted December 6, 2013 Report Share Posted December 6, 2013 (edited) Read this from Jim Snell http://www.gasgas.co...aust-clean.html going to try it on my mid box. Edited December 6, 2013 by bilks 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 6, 2013 Report Share Posted December 6, 2013 Yes, the early box was steel. I do like Jon`s idea of brake fluid as an alternative. But a torch will burn all deposits away. Dangerous and messy yes, but so is most methods. Quote Link to comment Share on other sites More sharing options...
madmostin Posted December 7, 2013 Report Share Posted December 7, 2013 Be very careful aluminium can disappear using caustic soda (this was on a beta rev3 mid section) it went in the bin! and a friend had to buy a new one Steel is fine with it Rich Oh dear unlucky!! Quote Link to comment Share on other sites More sharing options...
wobblenorbed Posted December 7, 2013 Report Share Posted December 7, 2013 Just because a magnet sticks doesn`t mean that something is steel, it could be aluminium with steel inards. You have been warned. Good luck. Quote Link to comment Share on other sites More sharing options...
chris west Posted December 8, 2013 Author Report Share Posted December 8, 2013 The exhaust has been soaking for two days . Weird ice like crystals developing in pipe . Carbon loosening . Quote Link to comment Share on other sites More sharing options...
dadof2 Posted December 14, 2013 Report Share Posted December 14, 2013 Probably the best way to clean out an exhaust is to plug the end and fill it with methylene chloride (about 3£ per litre). Shake it once in a while or leave it overnight. Pour it oil and if you keep it in a tin (not plastic) container it can be reused several times. If the methylene chloride does not shift really hard burned on deposits in the front pipe near the barrel try spray on foaming oven cleaner, leave it to work then part fill the pipe with chippings, plug the ends and shake it. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted December 15, 2013 Report Share Posted December 15, 2013 Please be careful when using chemicals like methylene chloride and such. There are known hazards to skin, respiratory, and nervous system functions from incorrect contact. Google it and read the information about proper handling and disposal. 1 Quote Link to comment Share on other sites More sharing options...
cc181 Posted December 16, 2013 Report Share Posted December 16, 2013 Along the same lines of this thread I have an 04 GG 300 with the seperate silencer and mid-box. The carburation/mix ratio seams to leave the exhaust a little messy and I would like to clean it up some. The question I have is what is inside the mid-box. When I look inside I can see what looks like a baffle, some perferated material all through the box. Does this have any packing material in it or is it just empty behind it. I am leary of putting some kind of solvent in there to clean it if the is some kind of packing in there. My local dealer wasn't much help with the info. Thanks for any input. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted December 16, 2013 Report Share Posted December 16, 2013 Yes methylene chloride is rather nasty stuff, but caustic soda is none too pleasant either. I get mine from Smith and Allan and the safety data sheet is on their website. Metylene chloride will not harm metals or other exhaust packing materials, It WILL rapidly wreck rubber, plastics and paintwork. Quote Link to comment Share on other sites More sharing options...
