Seeley Hubs
griffiths of wales
I have just stripped down both wheels ready for rebuilding and am about to send off the hubs for anodising...my predicament; do I remove the 'redundant' cast features (raised boss with hole and slot) before I send them off?
Both hubs have features that are unused, think they were probably designed to cater for break activation...any thoughts..can't see a problem but thought I'd ask.
Cheers all, Mark.
According to a mate of mine who works at a platers/anodisers, anything with steel in or attached to it can't be done unless all steel is removed. I couldn't get my bottom fork yoke anodised unless the stem was pressed out first.
Can't help you as to whether you can remove those redundant bits though
I know steel doesn't anodise, what I meant was that I thought it would have no affect on the steel stem in the bottom yoke, but it 'buggers up' the process in some way so there can be no steel present in what is being anodised.
